The number on the cheek pad is the thickness in millimeters. Thinner pads can be applied to loosen the fit. Thicker pads can be applied to tighten the fit. All sizes of cheek pads will fit any size helmet.
a sa 39mm, 35mm, 31mm tak wiec wychodzi na to ze nawet jesli skorupa XL jest wieksza od L to jak dam grubsze poduchy na poliki to bedzie git
