Odp: Ktm SMC-R 2019
Czyli tak jak zwykła redukcja z międzygazem tylko automatycznie? Takich rzeczy to powinni na kurcie prawka uczyć ;)
Nie. To co piszesz to oczywista oczywistość. W trybie quickshiftera robi to automat, a to jest co innego:
MSR (Motor Slip Regulation) engine brake control, is a standard feature and it works in the opposite direction of the MTC. When, due to sudden down shifting or abrupt throttling-off, or if the engine drag torque gets too high, the ride-by-wire system balances throttle input as much as needed to ensure controlled deceleration. MSR complements the slipper clutch and is especially effective in low grip situations.
