Z tym napinaczem masz film na youtube albo w manualu jest rozpisane.
Z tego co widzę trzeba wyjąc napinacz, pompować kilka razy aby wycisnąć olej .
Ustawić - cofnąć napinacz przy pomocy podkładek 2 - 2,5mm - zamontować go dokręcić jedną śrubę i ważne nie wiem jak napisać zwolnić blokadę , aby napinacz się wysunął - prętem przez otwór w nakrętce.
Jak obejrzysz film to pewnie będzie to łatwiej obczaić (podobny napinacz mają też inne ktm)- w manulau masz to też ładnie opisane
A i znalazłem to o 300V - ja teraz wleje 300v 15w60 ( miałem syntetyk Ipone 10w60)
Alex Vicente hey man if you’re still interested I think I have gotten it figured out. After speaking with a German KTM tech, he gave me the scoop on why everyone has these issues.. Bottom line, the 690 is just too much of a beast on oil, it shears the 10w-60 oil way too quickly. Add to that, we have hydraulic cam chain tensioners. The fix for this is as follows: drain oil, set to top dead center, remove Cam Chain Tensioner.. Now, you can replace it, or you can just clean it by compressing it to pump out the oil, or you can just buy a new one. Also, very important, when you change the cam chain tensioner, make sure you change the crush washer, AND there’s an O-Ring about 2.5-3 inches into the cam chain tensioners cylinder, remove that with an o-ring pick (it’s far in - as it might be the problem), and then install a new one and the cam chain tensioner (pre-loaded down to 3mm less then fully compressed) it will lock in that position. When you put everything together you must release the CCT before you’re done, (after putting on the CCT top brace minus the small hex cap) do that by inserting an 8.4mm rod (so you don’t press the visible ball valve) and press with FORCE, and it will release! Now just screw on the hex cap and you’re all set, on top of that CCT change/repair, you also only ever want to use 15w60 oil, (Motul 300v 15w60, preferably), this will keep the engine oil from shearing and not pressurizing the hydraulic CCT! No idea why KTM doesn’t tell people this..
