jak poszukasz to znajdziesz. ja u siebie zmienilem polki od crfy i wsadzilem lagi od sxv wiec sie da tylko najpierw trzeba poszukac.
troche do przejrzenia. info zgromadzone jak przerabilem swego motonga.
Showa 47mm
Upper - 52.9mm
Lower - 58.3mm
WP 48mm
Upper - 54.0
Lower - 60.0
[url]http://www.dirtbikeworld.net/forum/archive/index.php/t-33447.html[/url]
SXV
Top clamp area: 53.70mm
Bottom clamp area: 59.06mm
[url]http://www.apriliaforum.com/forums/showthread.php?220149-Fork-dimensions[/url]
Top Clamp = O53.8mm
Bottom Clamp = O59.1mm
[url]http://www.apriliaforum.com/forums/showthread.php?258169-Forks-amp-Triples&p=3210421&viewfull=1#post3210421[/url]
crf axle
20 mm front 25 mm rear
Rear bearings are 6905 2rs and fronts are 6904 2rs.
xr axle
17 mm front 27mm rear
sxv axle
25 mm front ?? rear
I measure the threaded end to be 24.9mm (for a 25mm bore bearing and fork leg bore) and 27.9mm on the opposite (shouldered) end for a 28mm fork leg bore.
The front axle is the same for all years of the RXV and SXV, but I'm not sure if the MXV axle is the same or not...
[url]http://www.supermotoforum.co.uk/bike-builds/41203-project-fat-pig-xr650r.html[/url]
[url]http://www.supermotoforum.co.uk/supermoto-gallery/33122-new-ish-me-retro-moto-anyone-else-riding-vintage-machinery-2.html#post259547\[/url]
Honda CRF150F
