Dokladnie tak :) , a tu copy paste z ktmforum....
Mark the tyre and the ground. Push the bike forward one turn of the wheel and mark the ground again.
Measure the distance in mm.
This is the WS setting you need to enter.
There is a three wire connector on the speedo - black, brown and red. Disconnect it… or chop the black wire and leave it chopped because the function of that wire is to inhibit wheel size adjustment, that’s all.
The speedo has a + button, a - button and another button that is called the MODE button.
Press the mode button a few times until the hours display is showing, then press and hold it until the display changes and little figures around the edge start to flash.
You can select trip meters, lap timers, kph or mph in this screen. + selects it, - deselects it.
Press the mode button around 11 times until WS starts flashing. Then press + or - to set the figure to 2205 or whatever your wheel measures.
Then press and hold MODE again to go back to normal display
http://adventuresklep.pl
