Temat: DR-Z 400 łożyska
Witam,
Dla potomnych
I just bought all my bearings today from SKF. The main crank bearings are made for Suzuki and are only 18mm thick. SKF only do a 19mm so I have ordered some with my new conrod kit that is after market.
I am replacing all the ball bearing bearings as I've split the motor so to speak.... I had to buy a second hand bottom end because my conrod broke and took most of the bottom end with it.
Bearings:
2 x 6306R/3BYR1 - SKF 6306-2RS 30x72x19 (won't work - must be 30x72x18)
1 x 63/22LAX - SKF 63/22-2RS C3 22x56x16 (not cheap!)
1 x 6205 VIS - SKF 6205-2RS C3 25x52x15
1 x 6905 - SKF 6905-2RS C3 25x42x9
2 x 6203 - SKF 6203-2RS C3 17x40x12
2 x 6302 - SKF 6302-2RS C3 15x42x13
Just remember to pop the rubber seals off the bearings except the one side on the counter shaft bearing.
Some seals that you may wish to replace are as follows:
Crank shaft Oil Seal (14X24X6)
Gear Lever oil seal (14x22x6) - I've also seen it ref. as 13X22X6 but mind was a 14x22x6.
Counter shaft O ring (D: 2.5 ID: 21.0)
Counter shaft seal (will have to check mine)
Starter O RING (D:3.0 ID:24.5)
Oil filter O RING (D:2.4 ID:52.6)
Oil filter O RING (D:1.9 ID:13)
If I think of anything else, I'll post it on here! Should have mind together soon.
Ceny
Optimal.pl
63/22 2RSC3 - KOYO w cenie 33,12 zł.
6205 2RSC3 - KOYO w cenie 11,98 zł.
6905 2RS - KOYO w cenie 34,93 zł.
6203 2RSC3 - KOYO - w cenie 8,73 zł.
6302 2RSC3 - KOYO - w cenie 10,18 zł.
Towar dostępny od ręki na magazynie .
Podane ceny są cenami netto . Trzeba doliczyć Vat.
Łożyska KOYO są produkcji Japońskiej .
P.W OPTIMAL
Piotrek
