Według rocznika 2006 cylinder dokręcasz z siłą 40NM
A reszta tak:
Sump Allen screw, transmission torque, clutch torque, ignition torque M6 10 Nm
Oil empty screw cap M16x1.5 20 Nm
Oil load screw cap M20x1.5 20 Nm
Oil net filter screw cap M28x1.5 15 Nm
Oil filter cartridge cover Allen screws M6 10 Nm
Engine oil pump body screws M6 10 Nm
Head-cylinder lock-nuts M10 40 Nm
Head-cylinder tigyhtening flanged nuts M8 20 Nm
Head-cylinder tigyhtening flanged nuts M6 12 Nm
Head-cylinder screw fasteners M8 20 Nm
Camshaft bearing cap Allen screw M6 12 Nm
Camshaft flanged nut cap M6 10 Nm
Distribution chain tensioner Allen screws M6 10 Nm
Water pump cover Allen screws M6 10 Nm
Water pump rotor M8 Loctite 243 + 15 Nm
Head cover Allen screws M6 10 Nm
Primary pinion hexagon nut M20x1.25 Loctite 270 + 100 Nm
Clutch hub nut M18x1.5 Loctite 270 + 80 Nm
Clutch springs Allen nuts M6 8 Nm
Starter motor bush head Allen screws M5 Loctite 243 + 6 Nm
Starter motor fixing Allen screws M6 12 Nm
Mobile chain-guide fixing flanged screws M6 12 Nm
Ignition stator Allen screws M5 Loctite 243 + 8 Nm
Ignition pickup fixture Allen screws M5 8 Nm
Allen screws for gear-block M6 Loctite 243 + 10 Nm
Ignition flywheel flanged nut M12x1 60 Nm
Kickstart pedal screws M8 Loctite 243 + 25 Nm
Gear lever Allen screws M6 Loctite 243 + 10 Nm
Empty collector flanged nuts M6 Loctite 243 + 12 Nm
General screws/nuts M5 8 Nm
General screws/nuts M6 10 Nm
General screws/nuts M8 20 Nm
Front wheel pin flanged nut M20x1.5 40 Nm
Front brake caliper screw fasteners (END,MX) M8 25 Nm
Front brake disc screw fasteners M6 cl. 10.9 15 Nm
Rear brake disc screw fasteners M6 cl. 10.9 15 Nm
Upper fork head screw fasteners M8 20 Nm
Lower fork head screw fasteners M8 20 Nm
Paioli fork leg screw fasteners M6 12 Nm
Ohlins fork leg screw fasteners M8 12 Nm
Rear wheel pin flanged nut M22x1.5 80 Nm
Rear fork pin flanged nut M16x1.5 80 Nm
Handlebar tightener screw caps M8 20 Nm
Handlebar elastic support nut M10 35 Nm
Upper damper nut M10x1.25 40 Nm
Lower damper nut M10x1.25 35 Nm
Crown wheel nuts M8 35 Nm
Rear brake pedal adjustment nut M6 15 Nm
Engine fixing screws M10 45 Nm
General frame screws M6 10 Nm
M8 25 Nm
M10 45 Nm
General frame nuts M6 15Nm
M8 30Nm
M10 50 Nm
