Odp: [K] Olej motorex
Jakiego wy lejecie tego motula?
Według specyfikacji jest gorszy niż Castrol 10w50, który kosztuje 100PLN za 4L.
300V 10w40
PROPERTIES
Viscosity grade SAE J 300 10W-40
Density at 15°C (59°F) ASTM D1298 0.880
Viscosity at 100°C (212°F) ASTM D445 14 mm²/s
Viscosity at 40°C (104°F) ASTM D445 89.5 mm²/s
Viscosity index ASTM D2270 161
HTHS viscosity à150°C (302°F) ASTM D4741 4.19 mPa.s
Pour point ASTM D97 -36°C / -33°F
Flash point ASTM D92 226°C / 438°F
TBN ASTM D 2896 11.7 mg KOH/g
Castrol 10w50
API SL
JASO MA-2
Viscosity @ 100C, cSt ASTM D445 17.14
Viscosity @ 210F, SUS ASTM D2161 86.5
Viscosity @ 40C, cSt ASTM D445 110.0
Viscosity Index ASTM D2270 166
HT /HS Viscosity, cP min ASTM D4683 3.7
Pour Point, F (C) max ASTM D97 0 (-18)
Flash Point, PMCC, C min ASTM D93 >200
Density @ 15C, Relative ASTM D4052 0.850
Pounds per Gallon 7.076
VALVOLINE SYNPOWER 4T 10W-50
SAE Viscosity Grade 10W-50
Viscosity, mm2/s @ 100 ºC. ASTM D-445 17.8
Viscosity, mm2/s @ 40 ºC. ASTM D-445 118
Viscosity Index ASTM D-2270 168
TBN, mg KOH/g ASTM D-2896 6.30
Pour Point, ºC ASTM D-5950 -36
Specific Gravity @ 15.6°C. ASTM D-4052 0.854
Flash Point, COC, ºC. ASTM D-92 230
Obecnie na dniach będę zalewał tego Valvoline i sprawdzę jak się będzie zachowywał.
