supercorsa nie ma startu do d211 gp , niestety. Kupilem Michelin Pilot Slick supermoto pre cut. :)
Przod
[url]http://moto-images.caradisiac.com/IMG/jpg/1/3/7/5/9/supermoto-2.jpg[/url]
Srodek 100% Boki 60% 2010 rok za 90zl :) Gumka na olowku jest twardsza od gumy na tej oponie. :P
Z innej beczki. Sa oosby ktore jezdzily na Racetec interact K2 lub K3? Co powiecie o tych oponach?
P.S.
Znalazlem przypadakiem na zagranicznym forum. Moze komus sie przyda.
vendors list their recommended HOT tire pressures for 120/160 & 120/180 tires.
Helpful to keep a cheat sheet handy for when you're at the track.
Bridgestone 003 - 30 psi front, 30 psi rear
Bridgestone BT003 RS Track Day Tire 32 psi front, 31 psi rear
Bridgestone BT003 Pro DOT Race 31 psi front, 30 psi rear
Bridgestone R10 DOT Race 31 psi front, 33 psi rear
Bridgestone Superbike Slicks 31 psi front, 28 psi rear
Conti DOT - 30 psi front, 28 psi rear
Conti slicks - 29 psi front, 26 psi rear
Dunlop DOT - 33 psi front, 23 psi rear
Dunlop Q2's - 30 psi front, 30 psi rear COLD
Dunlop slicks -
Michelin Pilot Power, Power 2CT and Pilot Pure - 31 psi front, 28 psi rear COLD
Michelin Power Race and Power One - 31 psi front, 22 psi rear COLD
Michelin Power One 16.5 slicks - 31 psi front, 22 psi rear. COLD
Michelin slicks 17" - 31 psi front, 28 psi rear (1247A / 1847C generations) COLD
Pirelli DCIII - 33 psi front, 33 psi rear
Pirelli Supercorsa Pro DOT Race - 32 psi front, 28 psi rear
Pirelli Diablo DOT Race - 32 psi front, 28 psi rear
Pirelli Diablo SLICK - 32 psi front, 28 psi rear
